Dynamic Menu using PowerCMS Builder
Thread begun 10/23/2012 7:20 am by wrigd | Last modified 10/23/2012 9:12 am by Jason Byrnes | 1104 views | 1 replies |
wrigd
I am needing some assistance in applying a dynamic menu when adding new pages via PowerCMS builder and also how would it be best to construct the pages/templates in PowerCMS Builder to make this work.
Some of my menu items are 3 levels deep and I am at a loss at how I can implement the menu to work dynamically if the client was to add another page based on a template I have assigned in PowerCMS Builder, depending on if the page is a main page or a sub, sub page.
My menu set-up currently uses a separate php file constructed via CSSMenuWriter. All the menu items currently are set-up as static links so I have to manually edit the file if another page is added. This need to automatically update. Any help would be much appreciated. Thank you.
It can be done to use menu writer to create a dynamic menu, but is not supported.
if you would like help doing this, I would suggest signing up for a premiere support appointment where we can help you achieve this.
