check if record exists
Thread begun 10/22/2012 2:50 pm by randyw2394710 | Last modified 1/18/2013 9:10 am by Jason Byrnes | 6594 views | 17 replies |
randyw2394710
im trying to see if a record exists, if it does, then a div error with record name will appear. not insert it. if it doesnt exisit, then it will insert the record name, and create that folder, also give conformation of the name.
i have searched all the posts even mine still having problems!
change lines 57 - 69:
$colname_CheckRepeat = "-1";
if (isset($_POST['Gallery Name'])) {
  $colname_CheckRepeat = (get_magic_quotes_gpc()) ? $_POST['Gallery Name'] : addslashes($_POST['Gallery Name']);
mysql_select_db($database_PowerCMSConnection, $PowerCMSConnection);
$query_CheckRepeat = sprintf("SELECT 'Gallery Name' FROM pg1_gallery WHERE 'Gallery Name' = %s", GetSQLValueString($colname_CheckRepeat, "text"));
$CheckRepeat = mysql_query($query_CheckRepeat, $PowerCMSConnection) or die(mysql_error());
$row_CheckRepeat = mysql_fetch_assoc($CheckRepeat);
$totalRows_CheckRepeat = mysql_num_rows($CheckRepeat);
$query_CheckRepeat = "SELECT pg1_gallery.id FROM pg1_gallery";
$totalRows_CheckRepeat = mysql_num_rows($CheckRepeat);?>
randyw2394710
Now I get an error Unknown column '[Gallery Name]' in 'field list' which it does exist
Spaces should be avoided in field names, and in form element names.
You have used a space in the Gallery Name column of your database, and in the name of the Form element.
i recommend using the camelCase naming convention to avoid the use of spaces.
randyw2394710
check duplicate
  First, you need to create the recordset to filter the email address column on the email address form element.
the recordset will create a variable named:
$totalRows_RecordsetName
(where RecordsetName is the name of the recordset) with the number of records returned.
the idea is to use numeric validation to make sure that recordset does not return any records (is empty)
add server validation, chose numeric validation and set the server variable to:
Set the minimum number to -1 and the maximum number to 0.
to show the error message, use the validation show if behavior.
I have done this tutorial a few times now not working right
i have a page with model window for creating new gallery wich pops up after clicking add gallery enter the name it should pass or fail then confirm message or fail message should appear do i need the record sets on the main page or include
in your recordset, you are referancing a form element that does not exist.
you are using the GalleryName form element, but the text box:
<input type="text" id="addGallery" name="addGallery"/>
is named addGallery
randyw2394710
ok got error to appear, how do i close this, if they go to another page then back.
also how do i get success to work, close, this if they go to new page then back. and if does not exist insert
the validation failure is stored in a session.
you could add code to the page to clear the session after the </html> tag:
<?php if(sset($_SESSION['WAVT_chooseGallerytest_522_Errors'])) unset($_SESSION['WAVT_chooseGallerytest_522_Errors']); ?>
to insert when the name does not exist, you need to add an insert record behavior.
randyw2394710
now i get this message
Fatal error: Call to undefined function sset() in /home/content/96/8026696/html/admin_cms/chooseGallerytest.php on line 297
sorry, i had a typo, the code should be:
<?php if(isset($_SESSION['WAVT_chooseGallerytest_522_Errors'])) unset($_SESSION['WAVT_chooseGallerytest_522_Errors']); ?>
