Universal Email not sending email
Thread begun 10/19/2012 2:44 pm by sandy170299 | Last modified 10/22/2012 2:09 pm by Jason Byrnes | 2616 views | 3 replies |
sandy170299
I have a page that was built using Framework Builder and it's also a CMS, using Power CMS. On this page, I have also included a contact form, using Universal Email to send the message. I'm not sure what I've done wrong, but the email is not sending, nor is it redirecting to the thank you page.
Here is the link: contact.php
Who is your host?
In universal Email, what did you enter for the SMTP Server?
Is the From Address a valid email address for your domain?
Can you send a copy of the page so i can inspect the code.
Also, to help troubleshoot, add this code at line 1:
error_reporting
(E_ALL);
ini_set('disaplay_errors','on');
and then add this code just before the closing </body> tag:
<pre><?php var_dump($_SESSION); ?></pre>
sandy170299
Hi, Jason. It's working now. For some reason, the method="post" was missing from the form, and I think that's why it wasn't working. Seems to be fine now. I'll write back if it stops working for any reason. Thank you!
yeah, the default method is GET so if no method is specified, it will use the get method which wont trigger UE to send the email.
