CSS not rendering in IE & Firefox
Thread begun 10/19/2012 2:34 pm by kg_nsa395746 | Last modified 10/20/2012 11:30 am by kg_nsa395746 | 2802 views | 4 replies |
kg_nsa395746
I'm designing a website with CSS Sculpture. Is there a reason why the CSS isn't being read by IE and Firefox? It renders correctly in Chrome.
send a link where i can see the problem to investigate.
kg_nsa395746
Here's the link. index.php I moved the CSSSculptor folder to the "newdesign" folder so don't know if that caused the problem. But as I mentioned, Chrome doesn't seem to have a problem with the location of the CSS file. I've redirected the CSS back to the root directory but that didn't resolve the issue. I don't want to continue designing the website until I get this issue resolved. I'd like to avoid starting from scratch if possible. It's obvious that IE and Firefox aren't reading the CSS file.
Thanks for your prompt response and help, Jason.
kg_nsa395746
I completely recreated the site at this address with the same results: index.php.
kg_nsa395746
I believe I've fixed the problem. In recreating the site, I isolated the problem to an issue with the #outerWrapper #topNavigation code. Not sure exactly what was causing the problem but it seems to be corrected now.
