Where to apply customer discount
Thread begun 10/19/2012 1:14 am by malcolm230194 | Last modified 10/19/2012 8:56 am by Jason Byrnes | 888 views | 1 replies |
malcolm230194
I want to apply a customer discount for signing up to a news letter. My first thought was on the confirm page as they are already logged in. My problem is that the page reload resets the $_SESSION values to ' ' as they come from the post of the checkout page.
Earlier in the process adds complication as some users will have an account while others will be unregistered and I don't want to make it complicated for users.
Any ideas will be gratefully received.
setting a discount is done in the Cart object, the cart object will apply the discount if the conditions for the discount rule are satisfied, regardless of the page the user is on.
you say that reloading the confirm page resets the session variables to '', this should not be the case, the trigger for the code to set the session variables should be any form post, this would prevent the sessions from being cleared on page reload.
the discount rule should use a trigger to make sure the user ID session that is created by login is not empty, the login session would not be effected by the confirm page, it would be set by the login page.
