how to remove address bubble
Thread begun 10/18/2012 8:25 am by asnw0764437428 | Last modified 10/18/2012 1:31 pm by Jason Byrnes | 1757 views | 3 replies |
asnw0764437428
In the old version of Pro Maps to hide the Address Bubble you selected the option include driving directions and left everything else blank.
How do you hide the bubble now in the Design Extender version, as the process as above isn't working.
Also, I am a little annoyed in the fact the old version of Pro Maps is now not working as it should on previous clients websites. It is now showing driving directions from A - B even though I have left the address blank. Though I am thinking this may be a Google Issue. Please advise!!!
And today just upgraded to Design Extender I am faced with having to update clients websites extensively because Pro Maps now does not show up in CS4's Server Behaviours Panel to simply update pages with the old version of the map.
So far though overall Design Extender is great and I've only had it an hour or so :)
PS Forgot to mention: Do I need to use a Version 3 API key?
in the New v3 api, to close the info window on page load, find the following code:
// open info window for default address
if (isDefault) {
infowindow.open(map1,marker);
map1.setCenter(point);
and change it to:
if (isDefault) {
//infowindow.open(map1,marker);
Pro maps will not show in the server behaviors list, to edit an existing map, click the map placeholder in design view, then in the property inspector, click the edit button.
in the V3 api, the API key is optional.
asnw0764437428
That works a treat thanks with the new version of GMaps in Design Extender, but will I have to do this now every time I want to place a map on the page?? The old version all you had to do was tick the box "show driving directions" and the address bubble was hidden.
Which now contradicts my other question:
showthread.php?t=28783
Has Google change something within their map system as mentioned in other thread all sites were working ok up till this morning??
the older stand alone version used the V2 API, in the V2 api clicking driving directions would hide the info window.
in the newer version, it is using the V3 API, to hide the info window in the newer API, you need to manually edit the code.
