Redirect Problem
Thread begun 10/16/2012 1:24 pm by sjones435326 | Last modified 10/16/2012 5:51 pm by sjones435326 | 1322 views | 2 replies |
sjones435326
Redirect Problem
Hello, I am having an issue with a page redirecting.
I have tried commenting out the "rel2abs" code. I have tried it on multiple browsers. Last night I tried to update the "Library.php" file that did not make any difference, so I put the original back in that directory.
I am using DWCS4 and DA 2.1.0 I have included the .zip file
Can someone please look at this and give me some ideas of what I need to do to make this work?
Thank you!
there is a blank line between php tags that at line 30 that is mot likely causing the probelm.
line 29 - 31:
should be:
sjones435326
Thank you Jason, that worked perfectly. This forum is definitely one of the best maintained.
