Send email on checkout success
Thread begun 10/16/2012 11:32 am by Joe Lowery | Last modified 10/16/2012 1:13 pm by Jason Byrnes | 4507 views | 8 replies |
Joe Lowery
I'm trying to send a separate receipt to the client when someone checkouts successfully. The site is using Authorize.net SIM (remote checkout).
I put the Create Email Message sb on the checkout_success page and now am getting these error messages when I checkout:
Warning: require_once(../WA_eCart/muirhead_PHP.php) [function.require-once]: failed to open stream: No such file or directory in /home/muirhead/wwwroot/muirheadfoods.com/webassist/email/muirhead_receipt.php on line 4
Fatal error: require_once() [function.require]: Failed opening required '../WA_eCart/muirhead_PHP.php' (include_path='.:/usr/lib/php') in /home/muirhead/wwwroot/muirheadfoods.com/webassist/email/muirhead_receipt.php on line 4
I'm sure both muirhead_PHP.php and muirhead_receipt.php are on the remote server in their respective folders. What am I missing?
Thanks - Joe
the error is saying that there is a require once line on the webassist/email/muirhead_receipt.php file, but there should not be a require once line on that file, it should not be in the email file itself, but in the file you applied Universal Email to.
Joe Lowery
Okay, I removed that and now I'm getting the following:
Warning: require_once(../../Connections/connMuirhead_DB.php) [function.require-once]: failed to open stream: No such file or directory in /home/muirhead/wwwroot/muirheadfoods.com/webassist/email/muirhead_receipt.php on line 2
Fatal error: require_once() [function.require]: Failed opening required '../../Connections/connMuirhead_DB.php' (include_path='.:/usr/lib/php') in /home/muirhead/wwwroot/muirheadfoods.com/webassist/email/muirhead_receipt.php on line 2
I do have a recordset on the email page. Should I not have the connection call there?
- Joe
the require once for the connection is only moving down 2 directories:
it needs to move down 3:
../../../Connections/connMuirhead_DB.php
Joe Lowery
Inching close to a solution. I made that change and now get a new error:
Fatal error: Call to a member function GetContent() on a non-object in /home/muirhead/wwwroot/muirheadfoods.com/webassist/email/muirhead_receipt.php on line 4
Line 4 of that file reads: "$muirhead->GetContent();"
- Joe
delete that line, it goes along with the eCart object include.
Joe Lowery
Well, at least the failures are getting more impressive. The checkout appeared to go through and then, I got this on the screen:
A new order for MuirheadFoods.com
Order Submitted: 10-16-2012 | 3:40 PM EDT
Order ID: 6756
["Order ID: 6756" was repeated about 30 times ]
Order ID: 6756
Fatal error: Call to a member function IsEmpty() on a non-object in /home/muirhead/wwwroot/muirheadfoods.com/webassist/email/muirhead_receipt.php on line 113
The above (minus the repeating order ID # and error) was the start of the email and should not appear on screen?
What now? - Joe
(And thanks for slogging through this with me!)
Joe Lowery
re: Send email on checkout success
So I realized that I had the order ID in the loop and removed it, but I still don't know what to do about the eCart objects that are used in the page. Can I not put a display-only cart on the emailed page?
I've attached the email template page as a zip file in hopes that will help.
Best - Joe
