Javascrit issue
Thread begun 10/16/2012 9:44 am by tkendrickmail32213 | Last modified 10/17/2012 7:15 am by Jason Byrnes | 2818 views | 5 replies |
tkendrickmail32213
Javascrit issue
getting a javascript error after installing extensions:
at line 383 of file "c:\users\Me|AppData|Roaming|Adobe\DreamweaverCS6\en_US\Configuration\shared\WebAssist\FormBuilder\Library\WA_Configuration.js": to check has no properties
what extensions including the version numbers do you have installed?
tkendrickmail32213
I have all the extensions in the super suite. It looks like this could be form builder the error. I am using this on DW CS6.
so you are using the stand alone version of CSS form Builder?
The stand alone extensions are not compatible with DW CS6, you will need to use a previous version of Dreamweaver with the stand alone versions.
the newer supper suite extensions, Design Extender and Data Bridge (Which consolidate the stand alone extension into 2 installers) are the versions compatible with CS6. You will need to upgrade to the newer versions in order to use them in CS6, since you own the previous supper suite versions, you are eligible to upgrade to Data Bridge for $149.99 and Design Extender for $39.99. Contact the sales department if you have further questions.
tkendrickmail32213
I purchased the upgrade. I got this error after I installed it:
unable to finde WA_Memento.htm in the Configuration/Floaters directory. The floater will not be shown.
reset your workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
