Error on pages after upgrade to version 2
Thread begun 10/16/2012 8:59 am by mousework50137 | Last modified 10/18/2012 12:43 pm by Jason Byrnes | 5533 views | 13 replies |
mousework50137
Dear Webassist,
Upgraded to PowerGallery 2 today, from version 1 and followed the instructions you supply for the upgrade.
Now when trying to visit a page with a gallery on it I get the following error on the page,
Fatal error: Allowed memory size of 20971520 bytes exhausted (tried to allocate 2755 bytes) in /home/fhlinux007/f/fgeorobinson.com/user/htdocs/PowerGallery100/webassist/caching/PG_CachedResize_Image.php on line 117
the page in question is
coventry_builder_garage_conversion_gallery.php
Have I done something wrong.
I reapplied the code to the php page but still no better.
thanks
this is a limit on the memory usage set by the server.
try adding the following code to the webassist/caching/PG_CachedResize_Image.php at line 1:
ini_set
("memory_limit", "256M")
mousework50137
Thanks for the quick reply.
I have done as suggested but now the page just floods with code if you look at the live page,
The first lines of my my code now read
ini_set("memory_limit", "256M")
$resizeDir = getcwd();
chdir(dirname(__FILE__));
require_once("../framework/library.php");
chdir($resizeDir);
if (!class_exists("PG_CachedResize_Image")) {
if (!function_exists('mkdir_recursive')) {
function mkdir_recursive($pathname)
$old = umask(0);
is_dir(dirname($pathname)) || mkdir_recursive(dirname($pathname));
$retVal = is_dir($pathname) || @mkdir($pathname, 0777);
umask($old);
return $retVal;
you removed an opening php tag.
the first 4 lines:
should be:
mousework50137
It sort of cured the issue but all my thumbnails except the first one had broken link symbols in the gallery on the page, although the gallery admin page did show all the thumbnails.
I think I'll start a fresh using PG2.
Can I presume that If I was going to start again with a fresh install of PowerGallery 2 on this site, with a new database would I still need to adjust the file mentioned above?
yes, you will still run into the memory limit problem and will need to add the code that was previously suggested.
If you continue to have problems, let us know and i will start an incident to look into it with you.
mousework50137
hi,
OK,
I setup a new database, deleted all files for PowerGallery from the site.
Uploaded fresh PowerGallery files, v2, ran the install wizard, all ticks, created a gallery and could see the thumbnails in the admin pages, it even previewed ok in the admin pages.
Dropped the code onto the page, uploaded it and although it loads the thumbnails are missing and clicking on them just hangs the page.
Take a look at
coventry_builder_single_storey_extension_gallery.php
Cheers
Mark
mousework50137
Hi guys,
still struggling with this could you see my post from yesterday above please,
thanks
Mark
mousework50137
I have attached the file if that helps
