DA Search Wizard & Repeat Region
Thread begun 10/16/2012 7:28 am by salaroche | Last modified 10/17/2012 8:30 am by Jason Byrnes | 3254 views | 5 replies |
salaroche
Hi:
I'm combining the Data Assist Search Wizard with a table containing a Repeat Region and, basically, the combination is working OK, except that the page doesn't wait for the Search to be triggered and it displays a number of records by itself the first time it opens.
Is there any way to keep the page from displaying records when it first opens (before any search has been triggered)?
Also, is there any way to have a user-entered date (in the search form) displayed in the repeating region?
Just in case, attached you will find a copy of the page. The page is also using DA's Multiple Record Insert, but that is working OK.
Thank you for your attention
in the data assist search behavior, set the default where to:
0 != 0
to show the date entered on the search form, make note of the date element name, then use the following code on the results page:
Search Date: <?php echo(isset($_POST['dateElement'])?$_POST['dateElement']:""); ?>
where dateElement is the name of the Date Element
salaroche
Jason:
I entered 0 != 0 in the default WHERE clause of DA's search Behavior, but the Results table still displays some records when the page first opens. It doesn't wait for the Search form trigger.
The code you sent for the date element works perfectly well.
the previous search is stored in a session, it is probably remembering a previous search you performed.
close the browser completely and try again.
salaroche
Jason:
Thank you for your help. But the problem persists once I've closed and reopened the browser. Is there any way to clean the Results table every time the page reloads?
