Missing Session Variables
Thread begun 10/16/2012 5:42 am by Mike Perry | Last modified 10/16/2012 12:09 pm by Mike Perry | 2936 views | 4 replies |
Mike Perry
I have a confirm page with all the eCart Set Session Value behaviors in place. However the eCart Session Bindings are not showing on the Bindings panel.
The eCart object is set to store variables in session.
Thanks,
Mike
which session bindings are missing?
can you send a screen shot showing what is in the session collection and description of bindings you expect to find there?
Mike Perry
Two Images attached.
Confirm2011 is screenshot in DW showing the associated bindings. This is from the page for the site I did last year.
Confirm2012.jpg is the new page, I'm redoing the site using Framework. The bindings are missing; the page code setting variables is in both pages.
Sample:
if (!session_id()) session_start();
if(
$_SERVER["REQUEST_METHOD"] == "POST")     {
$_SESSION["eCartCheckoutForm_firstname"] = "".((isset($_POST["firstname"]))?$_POST["firstname"]:"")  ."";
Thanks,
did you copy the session code? or use the Set Session Variable behavior to add it? copying the code will not add the binding to the session list.
to add the binding in the session list, you will need to add it manually.
on the bindings panel, click the plus button and select Session. set the name to eCartCheckoutForm_firstname
Mike Perry
I may have copied -- couldn't remember how I set it up last year. . .
Suspected that was the issue, but was worth checking.
Thanks, Jason. . .
