Empty Results page
Thread begun 10/15/2012 6:38 pm by bjgarner241692 | Last modified 11/28/2012 11:05 am by Ray Borduin | 5168 views | 8 replies |
bjgarner241692
Empty Results page
I have had this happen three times now, separate sites.
I step through the wizard, creating all the pages, let it run and when it is done, my Results page is blank. It has all of the php coding but nothing in the <body>
When I rerun it, it comes out fine.
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
bjgarner241692
Where would I put that code?
The pages do not exist until I run the Wizard. It is only after it runs to completion that I discover a blank page. At that point I simply delete them and run it again.
I cannot take the time to troubleshoot this for you. I just wanted to point out that it happens.
you would put that code on the results page that is created, once we know the error, we can investigate why it is showing blank in the browser.
bjgarner241692
Hi Jason,
The error is that there is nothing between <body> and </body>.
OK, I have not been able to reproduce this, can you give some more details on the application settings you are using when the problem occurs?
Are you using an application preset?
what settings are you using for the Field Settings?
is the preset creating the table for you, or using your own table? if your own table, what is the structure?
bjgarner241692
Did it again.
This time the table has 3 fields.
prID - INT 10 Primary Auto
prCode Tinytext
prDiscount Double 4,2
Creating 3 pages. Results, Insert, Update
Table is pre-existing.
While the wizard is running, after it has created the results page it comes up and says it is about to change results page, do you want to reload the page? I picked Yes.
I have done this with several websites, using various tables with various configurations. It fails the first time EVERY time. When I rerun the wizard, it will complete.
Here is the page created:
<?php require_once('../Connections/zeoconn.php'); ?>
require_once("../webassist/database_management/wa_appbuilder_php.php"); ?>
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue$theType$theDefinedValue ""$theNotDefinedValue ""
  if (
PHP_VERSION 6) {
$theValue get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" $theValue "'" "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue $theNotDefinedValue;
      break;
  return
$theValue;
$currentPage
$_SERVER["PHP_SELF"];
$maxRows_WADApromo
10;
$pageNum_WADApromo 0;
if (isset(
$_GET['pageNum_WADApromo'])) {
$pageNum_WADApromo $_GET['pageNum_WADApromo'];
$startRow_WADApromo $pageNum_WADApromo $maxRows_WADApromo;
mysql_select_db($database_zeoconn$zeoconn);
$query_WADApromo "SELECT prID, prCode, prDiscount FROM promo";
$query_limit_WADApromo sprintf("%s LIMIT %d, %d"$query_WADApromo$startRow_WADApromo$maxRows_WADApromo);
$WADApromo mysql_query($query_limit_WADApromo$zeoconn) or die(mysql_error());
$row_WADApromo mysql_fetch_assoc($WADApromo);
if (isset(
$_GET['totalRows_WADApromo'])) {
$totalRows_WADApromo $_GET['totalRows_WADApromo'];
} else {
$all_WADApromo mysql_query($query_WADApromo$zeoconn);
$totalRows_WADApromo mysql_num_rows($all_WADApromo);
$totalPages_WADApromo ceil($totalRows_WADApromo/$maxRows_WADApromo)-1;
$queryString_WADApromo
if (!empty(
$_SERVER['QUERY_STRING'])) {
$params explode("&"$_SERVER['QUERY_STRING']);
$newParams = array();
  foreach (
$params as $param) {
    if (
stristr($param"pageNum_WADApromo") == false &&
stristr($param"totalRows_WADApromo") == false) {
array_push($newParams$param);
  if (
count($newParams) != 0) {
$queryString_WADApromo "&" htmlentities(implode("&"$newParams));
$queryString_WADApromo sprintf("&totalRows_WADApromo=%d%s"$totalRows_WADApromo$queryString_WADApromo);
// WA Application Builder Delete
if (isset($_POST["Delete"]) || isset($_POST["Delete_x"])) // Trigger
$WA_connection $zeoconn;
$WA_table "promo";
$WA_redirectURL "promo_results.php?prID=".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"")  ."";
  if (
function_exists("rel2abs")) $WA_redirectURL $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString false;
$WA_fieldNamesStr "prID";
$WA_columnTypesStr "',none,''";
$WA_fieldValuesStr "".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"")  ."";
$WA_comparisonStr "=";
$WA_fieldNames explode("|"$WA_fieldNamesStr);
$WA_fieldValues explode($WA_AB_Split$WA_fieldValuesStr);
$WA_columns explode("|"$WA_columnTypesStr);
$WA_comparisions explode("|"$WA_comparisonStr);
$WA_connectionDB $database_zeoconn;
mysql_select_db($WA_connectionDB$WA_connection);
  if (!
session_id()) session_start();
$deleteParamsObj WA_AB_generateWhereClause($WA_fieldNames$WA_columns$WA_fieldValues$WA_comparisions);
$WA_Sql "DELETE FROM `" $WA_table "` WHERE " $deleteParamsObj->sqlWhereClause;
$MM_editCmd mysql_query($WA_Sql$WA_connection) or die(mysql_error());
  if (
$WA_redirectURL != "")  {
    if (
$WA_keepQueryString && $WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos($WA_redirectURL'?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_redirectURL);
//WA AltClass Iterator
class WA_AltClassIterator     {
  var
$DisplayIndex;
  var
$DisplayArray;
  function
WA_AltClassIterator($theDisplayArray = array(1)) {
$this->ClassCounter 0;
$this->ClassArray   $theDisplayArray;
  function
getClass($incrementClass)  {
    if (
sizeof($this->ClassArray) == 0) return "";
      if (
$incrementClass) {
      if (
$this->ClassCounter >= sizeof($this->ClassArray)) $this->ClassCounter 0;
$this->ClassCounter++;
    if (
$this->ClassCounter 0)
      return
$this->ClassArray[$this->ClassCounter-1];
    else
      return
$this->ClassArray[0];
//WA Alternating Class
$WARRT_AltClass1 = new WA_AltClassIterator(explode("|""|WADAResultsRowDark"));
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>Untitled Document</title>
</head>
<body>
</body>
</html>
mysql_free_result
($WADApromo);
If it ever says it was updated from another source and asks if you want to reload the page... say 'no'
I'm not sure what causes this, but it must be a delayed reaction from when we create a blank page before opening the page and adding content. So when you click 'yes' it reverts back to the blank page.
We haven't reproduced it, but from the description it seems that would be the cause. We'll continue to try to find a way to reproduce it so that we can get it fixed.
