Error loading DataAssist
Thread begun 8/06/2009 4:16 pm by Carl | Last modified 8/07/2009 11:05 am by Brad Lawryk | 3436 views | 7 replies |
Carl
I just installed the latest version of DataAssist and I now get this message when I try to use the extension
While executing onLoad in WA_AppBuilder.htm, the following
JavaScript error(s) occurred:
In file"WA_AppBuilder":
initializeUI is not defined
If anyone knows how to fix this that would be great.
I am running Dreamweaver CS4 on Vista 32-bit.
Thanks in advance.
Carl
Jimmy Wu
Try deleting your cache file. Here is a great thread giving details on how to do that:
showthread.php?t=1589
Brad Lawryk
Same problem exactly here all of a sudden. Was working - not its not.
The link you supplied does not mention how to go it on Vista. Where is the cache file on Vista?
Brad
Brad Lawryk
Did a file search for it on Vista - nothing.
Brad
Carl
Hi
I deleted the cache file but still no luck
Are there any other fixes? I have just reinstalled the latest update for a extension which I think is for DFP and no luck there either
(FYI Brad, the cache file is located in the C:\Users\[user_name]\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration folder, the AppData folder is hidden so you have to change the settings to view the hidden folder)
Brad Lawryk
Originally Said By: Carl
Ah! The ol' hidden file folder trick! Gotcha ... thanks Carl.
Brad
Jimmy Wu
Carl: Did you uninstall the previous version of DataAssist before installing the newest version? Can you try uninstalling the current DataAssist and installing it again?
Brad: Did deleting the winfilecache work for you?
Brad Lawryk
Originally Said By: Jimmy Wu
Yes it did, Jimmy. Thanks
Brad
