Inserting Multiple Records from a WADA Results Page
Thread begun 10/13/2012 10:29 pm by salaroche | Last modified 10/21/2012 7:53 am by salaroche | 2665 views | 4 replies |
salaroche
Hi:
I'm trying to convert a WADA Results page into and Insert Multiple Records page. I've added the Search form to the Results page and they both show and work OK. I've also added some form elements to the Results Table so that WA will allow me to insert an "Insert Multiple Records" behavior.
But when I try to add the values to be inserted, WA only gives me the "Search Form" option to choose from. The "Results Form" isn't available.
Is it even possible to accomplish what I'm trying to do? And, if it is, how do we go about it?
Thank you for your attention.
Using the results page asa multiple insert will be difficult to accomplish at best.
you will need to add a form around the results display, add the elements for inserting, then add the multiple insert behavior
salaroche
Jason:
OK. I think I now have an idea that might work. Let's see how it goes.
gavind
Hi Salaroche. I was wondering if you were able to get this fixed using the steps given already?
salaroche
Hi Gavind:
Actually, I'm using a different method now, searching with the DataAssist Search Wizard and displaying the results in a table with a Repeat Region. Basically it's working well and I'm now inserting multiple records from the results table, but there's still a little glitch that Jason will try to help me with soon.
Hope this helps.
