Power Messange
Thread begun 10/11/2012 4:58 pm by Gizza372666 | Last modified 10/15/2012 8:50 am by Jason Byrnes | 2372 views | 3 replies |
Gizza372666
Power Messange
On my admin_pm/audience_update.php I have added the following:
UserRegistrationDate
In the ‘Audience Filters’ drop-down list.
Can you please let me know why will only allow me 9 characters?
Can you also let me know how to remove the limit?
Finally I would like to add a calendar (data picker) onto this field. Can you please let me know where I can find the textfield so I can apply the data picker?
the reg date should allow you to enter the date in yyyy-mm-dd format
here is an updated copy of the admin_pm/scripts/filters.js file that should correct that.
the text box is generated dynamically, adding a date picker is not supported, if you need help doing this, i suggest signing up for a premiere support appointment.
Gizza372666
So is this means that data picker can be added for $49.99?
No a premiere support appointment is $99.99
