Starting the MySQL command line client
Thread begun 8/06/2009 3:16 pm by djogrady376174 | Last modified 8/07/2009 10:16 am by Jimmy Wu | 2617 views | 3 replies |
djogrady376174
I'm stuck on page 76 of the e-cart getting started guide, under the heading "To create the MySQL database," #2, where it says "On the computer that has MySQL installed, start the MySQL command line client (Windows)... by selecting Start>MySQL>MySQL Server>4.x>MySQL Command Line Client."
When I click on the start button, I don't see MySQL as an option.
Is there an alternative way to access the MySQL command line client?
I have MySQL and PHP installed as parts of XAMPP.
Dan
Jimmy Wu
If you open up a terminal window, type in the following command:
mysql -u<username> -p<password>
where <username> is the username you set up for your mysql and <password> is the password that you set up for that username.
This should get you to the mysql command line client. You should see something similar to this:
mysql>
at the beginning of the line.
djogrady376174
starting the MySQL command line client
Thank you Jimmy. However, I don't know what you mean by a "terminal window."
How do I open a terminal window?
Jimmy Wu
I'm sorry, I meant command prompt. The terminal window is the equivalent on a Mac machine.
The command prompt can be accessed through Accessories on the start menu.
