Delete file server behavior
Thread begun 10/11/2012 9:07 am by dvan_zelst | Last modified 10/12/2012 8:04 am by Jason Byrnes | 5283 views | 8 replies |
dvan_zelst
Hi Jason,
I need your help for this:
I created some insert,update,detail and result pages (standard) with DataAssist.
In the insert page i have a file field to upload an image to a folder.
This all works well, the file get's uploaded and the filename stored in the databse column.
Now i added a delete file behavior to the results page with the trigger set to Delete button pressed. This behavior code is placed before the delete record from database and it works great. The file get's deleted when delete is pressed and also the record is deleted from the database.
Now i do exactly the same on the detail page but where ever i place the delete file behavior code only the database record get's deleted but the file remains in the folder.
Do you have any idea why it works on the result page but not on the detail page when delete button is pressed?
Thanks for your advice.
without seeing the code, my only guess is that the delete record behavior comes first, and is redirecting to another page before the delete file behavior can run.
if you send the pages though, i can give a more concrete answer.
dvan_zelst
Hi Jason,
Attached is the detail page where the delete file behavior comes before the delete record behavior. I also tried to put it after the delete record but same result.
in the delete file behavior you are using the recordset to tell it which file to delete.
the problem with that is this:
on page load, the recordset uses the teamID querystring variable to filter the correct team record
when the form post, it reloads the page, this means the record is recreated. The action of the form does not pass the teamID url variable, so the recordset is empty.
since the recordset is empty, the delete behavior does not know which file to delete.
there are 2 ways to correct the problem:
1) add a hidden form element to the delete form and set the initial value for the hidden element to use the tamPicture column from the recordset. then in the delete file behavior, bind the file name to the hidden element.
2) change the code for the form tag:
<form class="DetailsPage DetailsPage Custom_CustomSharp" id="Details_Custom_CustomSharp" method="post"  action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
<form class="DetailsPage DetailsPage Custom_CustomSharp" id="Details_Custom_CustomSharp" method="post"  action="<?php echo(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)."?".$_SERVER["QUERY_STRING"]); ?>">
dvan_zelst
Hi Jason,
Thanks for your explanation. I did not realize that but understand now.
On the results page the recordset returns all records, no URL varaibles are used so when posting the form on the resultspage just re-crreates the recordset with records again. That's why it is working on the resultspage, however on the detail page you filter by URL variable the first time the page loads but when submitted there are no URL varaibles passed anymore resulting in an empty recordset for the delete file behavior to use. Am i correct?
If so then i understand.
I will add the hidden form element to store the filename for deletion and try again.
Thanks again Jason it was very helpfull.
dvan_zelst
Hi Jason,
I figured out i also had to include the hidden form element in the repeat region on the results page to make it work. Before it always deleted the wrong file because of the same reason.
Now it is working on the result page and on the detail page.
I also want to include the delete file behavior on the update page once a new file is uploaded. i know i can set the trigger on succesfull upload and again i need to include a hidden field that holds the teamPicture filename.
My question is: when i look at the hidden form element used on the update page, the hidden field value is: <?php echo($_GET["invalid"])((isset?ValidatedField("teamsupdate","WADAUpdateRecordID"):$_GET["teamID"])); ?>
Now i was wondering which binding generates this code when adding such value manually to a hidden form? Do i need similar code holding my teamPicture filename?
If i choose a binding for the hidden element value the code is without the '($_GET["invalid"])' code.
All is working now though also the update page but just wonder if this code has to be handcoded or comes from a binding.
that is the hidden element for the pictureID, not for the picture name.
you need to have another hidden element that is bound to the picture name column of the recordset.
dvan_zelst
Hi Jason,
I know and already have the extra hiddenfield. All is working well now.
I was just wondering which binding generates the code used in the hidden form element 'WADAUpdateRecordID' value field? <?php echo($_GET["invalid"])((isset?ValidatedField("teamsupdate","WADAUpdateRecordID"):$_GET["teamID"])); ?>
Thanks.
that code is not generated by a binding, it is generated by the wizard.
the validation failure passed a querystring back:
update.php? invalid=true
this querystring is used to tell the form element whether to use the Validated entries value or the recordset value (or in the case of this element the URL variable) as the initial value.
this is done to preserve any changes that might be made, say the user changes the first name, but validation fails for another element, it will retain the changed first name instead of defaulting back to what is in the recordset.
it uses a shortened if statement called a ternary expression. the format of a ternary exrpesing is:
(question)?if true:if false;
in this case, it's looking to see if the "invalid" URL variable is set, if it is, it uses the validated entries binding. if not, it uses the teamID URL variable
