Alternating a menu system...
Thread begun 10/10/2012 5:32 pm by Christopher West | Last modified 10/11/2012 12:06 pm by Christopher West | 2520 views | 6 replies |
Hi there I am trying to alternate some HTML code (together with some PHP that will allow dynamic menu names and menu icons (so that I have a icon above the first menu name, then icon below the menu name...so on and so forth..
I found that I needed to use a PHP modulator to create this: The below example code shows the menu working how I want it (but in this example its just static menu items) But need for the menu items to be replaced with dynamic ones from the record set. Could you help to insert the dynamic code replacing the static menu items below (<p>Home</p> AND <p>Domestic</p> I have been experiementing with different approaches but nothing works as of yet :(
I did try the below code without any HTML in the echo and just simple echo'd the dymanic code from my record set..however it only displayed the first record so it wasnt going through the whole recordset...then I stupidly messed around with the code putting in a repeat region around the below code and changed some of the references then I got the recordset working however it was echo'ing duplicates (eg HOME HOME DOMESTIC DOMESTIC). So not sure why that way :-/
for($i = 0; $i < $totalRows_rsTopMenu; $i++)
$row = mysql_fetch_array($rsTopMenu);
if($i % 2) {
echo '<div class="nav"><p>Home</p><p><img src="../images/hand.jpg" width="38" height="44"></p></div>';
} else {
echo '<div class="nav"><p><img src="../images/hand.jpg" width="38" height="44"></p><p>Domestic</p></div>'; }
my recordset is:
mysql_select_db($database_rainbowdb, $rainbowdb);
$query_rsTopMenu = "SELECT * FROM topmenu";
$rsTopMenu = mysql_query($query_rsTopMenu, $rainbowdb) or die(mysql_error());
$row_rsTopMenu = mysql_fetch_assoc($rsTopMenu);
$totalRows_rsTopMenu = mysql_num_rows($rsTopMenu);
Regards
Chris
using a for loop like that is not the right way to do this. Use a repeat region, before the repeat region code, initialize $i = 0, do the modulus comparison inside the repeat region, and increment $i as the last instruction of the repeat:
<?php $i 0// initialize $i ?>
do { // start repeat ?>
if($i 2) { // Modulus comparison
echo("Home<br />");
    } else {
        echo(
"Domestic<br />");
$i++;  // increment $i
} while ($row_rsTopMenu mysql_fetch_assoc($rsTopMenu)); // end repeat?>
That makes sense :) ...but in the echo I want to put this code in.....
echo('<div class="nav"><p style="margin-bottom:15px"><img src="../images/hand.jpg" width="38" height="44"></p><p>Domestic</p></div>');
....and where you see Domestic I want to replace with this....
<?php echo $row_rsTopMenu['TopMenuName']; ?>
So that any menu items stored in the database are displayed (rather then static content) But how can i put this into the echo (where Domestic is as its not allowing me to :(
Chris
Well I did some experimenting and got it to work in reverse:
echo('<div class="nav"><p style="margin-bottom:15px">'.$row_rsTopMenu['TopMenuName'].'</p><p><img src="../images/hand.jpg" width="38" height="44"></p></div>');
But just wondered why my database is displaying sequencually from right to left rather then from left to right
use:
echo('<div class="nav"><p style="margin-bottom:15px"><img  src="../images/hand.jpg" width="38" height="44"></p><p>'.$row_rsTopMenu['TopMenuName'].'</p></div>');
isnt that the same code that I put in after I edited my reply ;-)
My follow up question though is that I had to ORDER bt DESC to get the menu items in correct order since they were displaying from right to left. Which I did find a little odd because if I were to write the code manually without using dynamic data I wouldnt need to write the code in reverse (if you know what Im getting at) :)
Just wondered why I needed to do ORDER by DESC rather then leave it as default.
Chris
your edit that contained that code was made a minute after i posted.
the order by clause is setting the order of the results, the default is to use ascending, sounds like you want to use descending, so need to add the order by clause.
Thanks Jason :)
