wrong content is diaplaying
Thread begun 10/10/2012 10:20 am by JamieEff | Last modified 10/12/2012 9:08 am by JamieEff | 3512 views | 7 replies |
JamieEff
Hi Jason
Am trying to get this simple 'menu' working on this page news.php (the purple box).
When you click each link it goes to the right page but displays only the most recent article...
Have attached the file itself here as well
Cheers
Jamie
where you are trying to show the menu and the selected content area on the same page, you need to have 2 recordsets, one that is used to populate the menu, the second needs to be configured to filter the ContentPageSetOrder column on the zNews querystring variable that is being passed.
JamieEff
but6 I am just copying one that I created some time ago (see attached) which only has the one recordset and does what I am trying to get the other one to do....why would this one work and not the other?
cheers
Jamie
on the news page, change:
include('WA_CMS/addtosite.php');
echo
WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'zNews', 'Title', false, $row_NewsPanelRS['ContentPageSetOrder']);
?></h2>
echo
WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'zNews', 'Content', false, $row_NewsPanelRS['ContentPageSetOrder']);
echo
WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'zNews', 'Title', false);
?></h2>
echo
WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'zNews', 'Content', false);
it works on the index page, because the the code to show the content is after the recordset loop meaning that the recordset is empty, so an empty value is passed by this code $row_NewsPanelRS['ContentPageSetOrder']
JamieEff
ahhhh ok thats done the trick
as ever, many thanks Jason
Jamie
JamieEff
Hey Jason
Using the same page as above... how would I get the date the entry was created?
have been trying to use
echo(
date("d/m/Y",strtotime($row_NewsPanelRS['ContentDate'])));
Obviously that doesnt work, but not sure what chanegs I would need to make to the recordset to get it to work
Many thanks
Jamie
you would need to create a new recordset as:
SELECT C2.ContentDate, C2.ContentGroup, C2.ContentPageSetOrder
FROM pcms2_contents AS C1 LEFT OUTER JOIN pcms2_contents AS C2 ON C2.ContentPagesetParentID = C1.ContentID
WHERE C1.ContentGroup = 'zNews' AND C2.ContentPageSetOrder = URLParam
GROUP BY C2.ContentPageSetOrder
ORDER BY C2.ContentPageSetOrder DESC
parameters:
type: Integer
default value: 1
Run Time value: $_GET['zNews']
JamieEff
thanks and have a great weekend
Jamie
