Multiple Records Not Showing
Thread begun 10/09/2012 10:21 am by vernon webb | Last modified 11/12/2012 1:21 pm by Jason Byrnes | 7255 views | 18 replies |
vernon webb
I have followed the instructions to a T and am not getting the expected results.
I have a form that submits two zip codes, those zip codes create a recordset of 2 values, the values submitted. Those values are written to the page so I know that the recordset is working properly. I create the Google map, select the Show Multiple option and tried both the "Coordinates" and the "Address" options with no success, all that shows on the map is the first record. Any ideas?
send a link where i can see the problem please.
most likely, the zoom level is set so that only one address marker shows, most likely if you set the zoom level out further, it will show both markers.
vernon webb
customer_notes_radias.php
it looks like your database has the zip field set as a number which is causing it to loose the leading 0 for the zip.
in the code, the zip returned is only 4 numbers:
zip: '7401',
use a text field type for the zip column so that it wont drop the leading 0.
vernon webb
I made the change to the database but made no difference...
in the pro maps interface, instead of leaving the address, city and state fields blank, use a space. so enter a space for the address city and state field, and bind the zip field t your recordset column.
vernon webb
Did not work. I decided to recreate the page without recrodsets and just enter 2 zip codes that I typed in, same problem.
customer_notes_maps.php
your page here:
does show both markers if you zoom out.
you need to set the zoom level out enough to be able to fit both markers in the frame.
vernon webb
How do you do that?
In the Pro Maps interfacer, you can set the Zoom Level on the 4th step.
see the attached screen shoot
