Email not sent upon form submit
Thread begun 8/06/2009 1:53 pm by michellem310468 | Last modified 8/12/2009 2:59 pm by Eric Mittman | 3154 views | 6 replies |
michellem310468
I am using Universal Email to send a registration confirmation upon submission of a registration form. Everything works great but no email is ever sent to either the TO or CC recipients. Can't seem to figure out why. UE works fine when used with the "forgot password" function.
Not sure that the below code is of any help, but can anyone enlighten me as to what some of a the possible causes for this would be?
Thanks.
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "".$row_WAATKusers['UserEmail'] ."";include("WA_Universal_Email/WAUE_users_Registration_1.php");
//Send Mail All Entries
if (""!="") {
header("Location: ");
If your recordset does not contain a value for this then you will not get the email sent. As a test of this you can add this in just above the line that sets the recipient:
die("The value of the UserEmail column is ".$row_WAATKusers['UserEmail'] );
This will let you know if the value is getting set before the email is sent. Unless you see the email address in this message it will not be sent.
michellem310468
no luck
nothing new happened when I added die("The value of the UserEmail column is ".$row_WAATKusers['UserEmail'] );
Miguel
Try placing a redirect when it finish sending the email i had this problem the hole day discovered that theUE might have a bug if that is not filled.
I see you have
if (""!="") {
wich means you did not set a file to redirect after sending the email.
check this post i just made a few min ago
showthread.php?t=2911
even if you not using addt just add the file to redirect there like a thank you page or something and it will work :)
Sades, thanks for your insight.
michellem310468 did this do it for you?
If you are still having problems with this post back with the code you have the die statement in and the updated redirect page. If you have this die statement in the code above the recipient you should at the very least see the message that is in the quotes, if you see nothing and have this in the right place then the Universal Email server behavior is not being triggered. Please let us know how this is going for you.
michellem310468
yup - that fixed it. Thank.
That is good to hear, it is nice to get some outside help from the community, you guys are great.
