file_manipulation\helperphp.php on line 2
Thread begun 10/09/2012 5:10 am by eladgraphics386618 | Last modified 10/10/2012 8:09 am by Jason Byrnes | 2703 views | 3 replies |
eladgraphics386618
hello
I am using dw cs 6 and data bridge
when uploading file in the insert page I have this error messages (see attached)
I have done it before and it worked. seems like I don't really get the concept.
please tell me what I am doing wrong
this is a permissions issue.
the error is saying that the permissions on the C:\xampp\htdocs\tapifounwebsitenew\images\largesImages folder are not allowing the file to be created.
eladgraphics386618
Hello Jason
thanks for your time and a quick reply.
1. the folder in question contains the images I am trying to upload in the result, insert and update page. Is the problem has to do with the database or what is inside my database?
2. Can you direct me to where I can find a link to forget password tutorial to configure the forget password menu. I am a little bit confused and don't know what to choose.
thanks
eladgraphics
it has nothing to do with the database, it is a permissions issue. the upload is trying to create the uploaded file in that directory, since it already exists there, it is trying to create another copy of a different name, but the directory does not have the appropriate permissions to to create the file.
What version of security assist are you using?
Are you using Encryption for the password?
In security assist 2 The forgot password page is a complex page to create manually, I recommend using the security assist wizard to create the forgot password page instead of trying to do it manually.
