Security pages problem
Thread begun 10/08/2012 6:35 pm by lr_leal239405 | Last modified 10/12/2012 7:26 am by Jason Byrnes | 4342 views | 7 replies |
lr_leal239405
I ran the 'Create Security Pages' function and it created everything including the database. However when I fill the registration I keep getting the message "Invalid information, please check your entries and try again. " It comes back to the form and clears all my fields as well. I tried 3x but I can't get around it. What could be causing that?
send a copy of your registration page please.
lr_leal239405
I tried pasting the code but it won't show. Attached is the file.
the validation is failing, we need to get more details about why.
find this code:
PostResult($WAFV_Redirect,$WAFV_Errors,"registration");
and change it to:
die($WAFV_Errors);
this will wrote a coma separated list of failed validations to the screen, post this back so i can look into what is failing.
lr_leal239405
what I got was:
,13,14
thats the captcha and security question validation.
first thing to double check is that the server can properly save session variables.
use the session test page from the following thread to make sure sessions are working:
showpost.php?p=23826&postcount=2
if the session tet fails, you'll need to contact the host to have the session.save_path setting in the php.ini file fixed.
lr_leal239405
Ok, fixed server problem. Thanks. Still can't get past the security code validation. ??
