DataBridge 1.9 Server Validation FAILS
Thread begun 10/08/2012 5:12 pm by nickj | Last modified 10/10/2012 8:05 am by Jason Byrnes | 2614 views | 3 replies |
nickj
INSERT FORM build using 1.0.9. fails on the server validation. I can't find any tutorial or instruction on how to debug this error. The insert form just reloads a blank page. If I remove the validation it works so the validation is not being written completely.
The attached files are unedited and the insert form doesn't work, neither does the update.
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
nickj
errors
The insert page is working but not the update.
Notice: Undefined variable: conn_asbs in /home/breastsu/public_html/admin/CertMan/facility_update.php on line 10
Notice: Undefined variable: database_conn_asbs in /home/breastsu/public_html/admin/CertMan/facility_update.php on line 32
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/breastsu/public_html/admin/CertMan/facility_update.php on line 33
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/breastsu/public_html/admin/CertMan/facility_update.php on line 38
on the update page, the connection line is in the wrong place.
move the following code from line 47:
<?php require_once('../../Connections/conn_asbs.php'); ?>
to line 1
