DataBridge Preset
Thread begun 10/07/2012 3:07 am by dvan_zelst | Last modified 1/06/2014 8:05 am by Salah Heddad | 3986 views | 5 replies |
dvan_zelst
DataBridge Preset
I tried to import the DataAssist Orders Details Application Preset as mentioned in the tutorial but when selecting this ZIP file from the preset manager gives me a message:
The selected file is not a valid DB application preset.
Why?
I'm running DB v1.08 (latest) on DW_CS5.5 Windows7 x64.
Thanks.
after downloading the tutorial_preset.zip file, extract the contents.
In the preset manager, select Data Bridge - Preset from the product list, then click the import button.
browse to the folder that you extracted the tutorial_preset.zip archive to and select the tutorial_admin_preset.zip file.
repeat the steps, and this time select the tutorial_catalog_preset.zip file.
dvan_zelst
Dear Jason,
I'm refering to this file in the tutorial:
data-bridge-display-relational-tables-preset.zip
Inside this ZIP file is only another folder with the same name, no ZIP file inside.
If i choose the downloaded ZIP (link above) it does not import.
So either the import function has a problem or the ZIP file is not correct for importing.
Please advice which is true.
Thanks.
it's always helpful to be specific about which tutorial you are talking about to prevent confusion.
here is an updated copy if the preset that work for you. I will have the one in the tutorial fixed.
dvan_zelst
Thanks Jason!
Salah Heddad
thanks !
