Modifying Power CMS
Hello,
I've added a new select list to the update page that updates both the history and current tables. This all works well.
Next I tested the basic Insert New Record from Template but found an error where a default value is being checked.
Question: where in the code is this being validated so I can add the field name or remove the validation?
Details: Check attached Image for Error/Alert and Database details. The DB Does set a default value and also the INSERT code in Pages.php has been updated to also set a default value to both the History and Current tables.
