Registration page not working
Thread begun 10/05/2012 8:00 am by s.joiner74419001 | Last modified 10/09/2012 11:58 am by Jason Byrnes | 8818 views | 23 replies |
s.joiner74419001
I have created a Double Opt in Registration System from the web-assist tutorial. I have then tried to test it and on completion of the form, it displays the error message "invalid information .... "
Not sure why this is. I have recently upgraded from Security Assist to Databridge.
Attached is the registration page.
you have the "invalid information" message inside the Validated form show region, so that would mean that the form is not passing validation.
we need to know which validation is failing to be able to troubleshoot why.
change the following code:
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"registration");
die($WAFV_Errors);
this will write a comma separated list of umbers to help us determine which validation is causing the failure.
s.joiner74419001
s.joiner74419001 Registration page not working
The result was: -
,14
that is the validation for the security question.
looks like you have removed the security question from the form, but left the validation in place.
delete the following line to remove the security question validation:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Answer"])?$_POST["Security_Answer"]:"")) . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,14);
s.joiner74419001
user confirm page
Thanks Jason, thats solved that issue. Now it processes the form but it displays the "your Verification Link has expired link" message on the confirm page. And it doesn't send the email either.
I've attached the confirm page!
that means the reVerify recordset is not returning a result.
what is the link in your email?
s.joiner74419001
email Link
the link in the email "blank.php" is: -
<a href="http://localhost/team_root/user_confirm.php?id=<?php echo $_SESSION['SecurityAssist_user_id']; ?>?randomString=<?php echo $_SESSION['rpw']; ?>?email=<?php echo((isset($_POST["Registration_group_E_Mail"]))?$_POST["Registration_group_E_Mail"]:"") ?>">Click here to verify your email address</a>
i'm not asking about the code for the link, i'm asking about the link that is generated by the code.
s.joiner74419001
I'm not quite sure I understand what your asking. Where would I locate the link that is generated by the code?
when you register, you will be sent an email that contains a link to the user_confirm.php
you need to click the link in the email to access the user_confirm.php page.
the link passes information specific to your registration, this information is used to determine if you are valid user or not.
if your are a vlid user, the email verified column can be updated. if not, the email verified column cannot be updated.
