Download Count update always the same ID
Thread begun 10/03/2012 6:03 pm by Vinicios Nussemeyer | Last modified 10/09/2012 10:27 am by Jason Byrnes | 5888 views | 5 replies |
Vinicios Nussemeyer
Hello
I applied the download count on the download page. When the user downloads the system increases and records in mysql. The problem is that the increment is always saved in the same file ID. If I have 10 files for download, the system updates ArquivoID always the same in mysql. For example: If I download the file once with ID 1 and ID 2 to 10 times, the system always update the ID 1.
The column in the table is CountDownload files and defaults ZERO.
key column: ArquivoID and value: $ row_rsArquivos ['ArquivoID']
Tanks
it's because you are using the ID from the recordset as the key column value
that recordset will always be at record 1 when the download is executed.
you don't include a lot of detail on how the page is set up, but i'm assuming you have a repeat region on the page? in the repeat region you have a form that sends the download file name using a hidden form element? if that is correct, you need another hidden form element that passes the ID and use that hidden form element as the key column value
Vinicios Nussemeyer
Hello Jason.
Yes, the page is set up like you said. I applied another hidden element on the form but still did not work.
Follows the code of the page:
session_start(); // Inicia a session
include "functions.php"; // arquivo de funções.
session_checker(); // chama a função que verifica se a session iniciada da acesso à página.
<?php require_once('Connections/conn.php'); ?>
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$maxRows_rsArquivos = 15;
$pageNum_rsArquivos = 0;
if (isset($_GET['pageNum_rsArquivos'])) {
$pageNum_rsArquivos = $_GET['pageNum_rsArquivos'];
$startRow_rsArquivos = $pageNum_rsArquivos * $maxRows_rsArquivos;
mysql_select_db($database_conn, $conn);
$query_rsArquivos = "SELECT `arquivos`.*, `users`.*, `users`.`UserFirstName` AS Professor FROM `arquivos` LEFT JOIN `users` ON `arquivos`.`Professor` = `users`.`UserID` WHERE arquivos.Serie = 3 AND arquivos.Ativo = 1";
$query_limit_rsArquivos = sprintf("%s LIMIT %d, %d", $query_rsArquivos, $startRow_rsArquivos, $maxRows_rsArquivos);
$rsArquivos = mysql_query($query_limit_rsArquivos, $conn) or die(mysql_error());
$row_rsArquivos = mysql_fetch_assoc($rsArquivos);
if (isset($_GET['totalRows_rsArquivos'])) {
$totalRows_rsArquivos = $_GET['totalRows_rsArquivos'];
} else {
$all_rsArquivos = mysql_query($query_rsArquivos);
$totalRows_rsArquivos = mysql_num_rows($all_rsArquivos);
$totalPages_rsArquivos = ceil($totalRows_rsArquivos/$maxRows_rsArquivos)-1;?>
WA_DFP_SetupDownloadStatusStruct("WA_DownloadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_DownloadFile("WA_DownloadResult1", "../../downloads", "".((isset($_POST["hiddenField"]))?$_POST["hiddenField"]:"") ."", "[FileName]", 1, $database_conn, $conn, "arquivos", "ArquivoID", "".$row_rsArquivos['ArquivoID'] ."", "CountDownload");
<head>
<title>Downloads 8 Série</title>
<link href="css/styles_downloads_arquivos.css" rel="stylesheet" type="text/css" />
<style type="text/css">
.Spacious {
padding-top: 3px;
padding-right: 7px;
padding-bottom: 3px;
padding-left: 7px;
text-transform: uppercase;
background-image: -moz-linear-gradient(top, #18536b, #1c5a73);
background-image: -o-linear-gradient(top, #18536b, #1c5a73);
background-image: -webkit-linear-gradient(#18536b, #1c5a73);
background-image: -webkit-gradient(linear,left top, left bottom, color-stop(0, #18536b), color-stop(1, #1c5a73));
background-image: linear-gradient(top, #18536b, #1c5a73);
filter: progid:DXImageTransform.Microsoft.Gradient(StartColorStr='#18536b', EndColorStr='#1c5a73', GradientType=0);
-ms-filter: progid:DXImageTransform.Microsoft.Gradient(StartColorStr='#18536b', EndColorStr='#1c5a73', GradientType=0);
background-position: 0 16px;
border-style: solid;
color: #cccccc;
background-color: #1c5a73;
border-color: #636668;
font-family: Arial, Verdana, sans-serif;
font-size: 0.6em;
border-width: 1px;
.Spacious:hover {
background: none;
color: #ffffff;
background-color: #18536b;
</style>
</head>
<body>
<div id="BannerTopoInst">
<table width="940" border="0" cellspacing="0" cellpadding="0">
<tr>
<td colspan="4"><img src="assets/images/clearpixel.gif" width="806" height="45" border="0" /></td>
</tr>
<tr>
<td width="150">&nbsp;</td>
<td width="616"><span class="BannerTopoInstTitulo">Download</span><span class="BannerTopoInstTituloActive">Material Acadêmico</span></td></td>
<td width="23"><img src="assets/images/clearpixel.gif" width="20" height="45" border="0" /></td>
</tr>
</table>
</div>
<span class="Texto1"><?php echo "Bem vindo <strong>". $_SESSION['nome'] ." ". $_SESSION['sobrenome'] . "</strong>!<br />
Você está acessando a área restrita de downloads para os alunos cadastrados no Sistema de Ensino Universo!<br />
Seu último login foi em: ". date('d/m/Y', strtotime($_SESSION['data_ultimo_login'])) . '-' . date('H:i:s', strtotime($_SESSION['data_ultimo_login'])) ." <br />";
?></span><br />
<p>
<p class="ArquivosTitulo2">Material acadêmico / 3º Ano</span> - <a href="logout.php">SAIR</a><br /></p>
<?php if ($totalRows_rsArquivos == 0) { // Show if recordset empty ?>
<p class="FormCampoObrigatorio">No momento, não existem materiais acadêmicos para download para esta série.</p>
<?php } // Show if recordset empty ?>
<?php if ($totalRows_rsArquivos > 0) { // Show if recordset not empty ?>
<table width="940" border="0" cellspacing="2" cellpadding="0">
<tr>
<td width="228" height="25" bgcolor="#EBEBEB" class="ArquivosTitulo1">Disciplina</td>
<td width="301" bgcolor="#EBEBEB" class="ArquivosTitulo1">Título</td>
<td width="293" height="25" bgcolor="#EBEBEB" class="ArquivosTitulo1">Professor</td>
<td width="108" height="25" align="center" bgcolor="#EBEBEB" class="ArquivosTitulo1">Ação</td>
</tr>
<tr>
<td height="10" colspan="4"><img src="assets/images/clearpixel.gif" width="10" height="10" border="0" /></td>
</tr>
<?php do { ?>
<tr>
<td class="Texto1"><?php echo $row_rsArquivos['Disciplina']; ?></td>
<td class="Texto1"><?php echo $row_rsArquivos['Titulo']; ?></td>
<td class="Texto1"><?php echo $row_rsArquivos['Professor']; ?></td>
<td><form id="form1" name="form1" method="post" action="">
<input type="submit" value="Download" class="Spacious" id="Spacious" name="Spacious" />
<input name="hiddenField" type="hidden" id="hiddenField" value="<?php echo $row_rsArquivos['ProductLocation']; ?>" />
<input name="hiddenField2" type="hidden" id="hiddenField2" value="<?php echo((isset($_POST["hiddenField"]))?$_POST["hiddenField"]:"") ?>" />
</form></td>
</tr>
<?php } while ($row_rsArquivos = mysql_fetch_assoc($rsArquivos)); ?>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
<?php } // Show if recordset not empty ?>
</body>
</html>
mysql_free_result($rsArquivos);
Thank you.
2 problems:
1) In the download behavior, it is still set to use the ArquivoID column from the recordset for the key column value
2) the hidden form elment you added is set to use the value from the first hidden field:
it should be set to use the ArquivoID column from the recordset.
the idea is to bind the hidden field to the ID column from the recordset,
and in the Download server behavior bind the key column value to the hidden field.
NOTE: instead of pasting the code for the page, please compress the page to a zip archive and attach the zip file to your response.
Vinicios Nussemeyer
Hello Jason.
I applied the changes and now gives this error:
You have an error in your SQL syntax near 'Etnicos_Oriente Medio.pdf' at line 1
for the key column value in the download behavior, you are using the ProductLocation column of the rsArquivos recordset.
This is not what I have been telling you to do.
bind the Key Column Value setting to the hiddenField2 form element.
