cusomised menu
Thread begun 10/02/2012 5:02 pm by Gizza372666 | Last modified 10/05/2012 11:22 am by Jason Byrnes | 3167 views | 5 replies |
Gizza372666
cusomised menu
hi I have created a menu and I have problem displaying this menu on my power messenger's admin section.
PowerMessengerFiles/admin_pm/inc_menu.php
Can you please let me know how to fix this?
thanks
the menu for power messenger is generated by the webassist/plugins/admin_menu/menu.php file.
You should add your custom menu items to that file.
Gizza372666
ok Thanks
Thanks for this.
I have couple more questions.
Q1. Can you please let me know if there is a limitation on the amount of emails I will be able to sent?
I have 5 copies of this solution but I never put it to a big challenge (5 million emails). If there will be no problem, can you please let me know approximately how long it will take me to send 5 million emails?
Q2. Do you know any hosting package who will be able to manage this 100%?
Finally as I have 5 copies already and I keep buying and selling more, is there any way for me to bye white label copies (all the files and folder names as well as the programmers comments to change the word 'webassist' to my company name) I will sign a document if needed to confirm that the software is yours and just as a reseller I use a white label. If yes this will be great, if yes, is there any easy instructions for me to do this. I want to give full FTP access to my clients but if they see your name, I will lose business.
You will be able to track my copies anyway from the serial number so I know that I will have to buy one copy for every domain.
Email limitations are set by the host.
They normally set limits to the number of emails that can be sent over a given period.
In power Messenger, in the email settings, you can set the Number Of emails to send at a time, how long to wait between each group. use these settings so that emails don't go over the limits imposed by the host.
5 Million emails i think will be pretty difficult to handle using a system like Power Messenger unless you break the mailing into smaller chunks at a time by creating audiences.
The difficult factor will be the time that the script needs to run.
you could break it up alphabetically to create audiences based on the "UserLastName" "Begins with" "a"
you can add multiple conditions to include "OR" "UserLastName" "Begins with" "b"
This way you can send a mailing to one audience, then send the mailing again to the other audiences still you get through the entire alphabet.
We dont offer a white labeled version of power messenger, but you can create your own, and reuse those files each time you install power messenger.
Gizza372666
Thank you very much for the info and help!
I have came across an issue with the timezone. the server is in usa and my client in uk.
Can you please let me know why when I added the following line on my .htaccess file:
date.timezone="Europe/London"
the green and the blue circle show the uk time but the red the usa?
