javascript and memento error messages
Thread begun 10/02/2012 7:13 am by daniel276949 | Last modified 10/09/2012 11:53 am by Jason Byrnes | 2629 views | 5 replies |
daniel276949Beta Tester
i am having major error messages using dreamweaver CS6 and i have tried reinstalling DW and the attached screenshots of the errors... it started when Adobe automaticly updated the software... it was then that after the updates all the extensions vanished from the DW program... i checked the extension manager and found all the extensions were active... then i unchecked all DW extenstions shut down and restarted DW and then i re-checked all the extensions to re-enable them... then the trouble began... it started out with just WA extensions then affected 2 others and after all the problems and reinstalls i am down to just those in the screen shot... What do i do now as i cannot get rid of email... i really do not want to take another whole day to remove all adobe cs6 software and then reinstall all of them again... thanks, Daniel
Go to WebAssist -> Preferences in the Memento section Set the Show in dreamweaver option to Never.
In the RSS Section, check the option to disable all RSS Feeds and Check For Updates only when Memento opens.
Then go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
i am still getting the errors
i followed your instructions to a T and without success... i am still getting the error messages... What should i try now... Thank You
rokla393076
Memento
After every DW opening appears error message "The following JavaScript error occurred .../Webassist\LayoutManager\shared.js ... is not defined". I have read your instruction regarding Memento issue but the the problem remains.
Roland
