Repeated tables
Thread begun 10/02/2012 3:00 am by dvan_zelst | Last modified 10/02/2012 7:34 pm by dvan_zelst | 1496 views | 2 replies |
dvan_zelst
Repeated tables
I tried the Databridge repeated tables but when i choose all records and 5 columns in the wizard it outputs the value -5 in the php resulting in a sql error. I have to manually change the repeat region behavior to set it again to all records.
If i choose a value for records (not all records) then it works normal.
Why it outputs a negative value when choosing all records in the wizard?
Thanks.
Code: $maxRows_rsItems = -5;
This is a bug in the Repeating table behavior that will be corrected in the next update to Data Bridge that should be released soon.
dvan_zelst
Hi Jason,
Thanks for your reply. Will wait for the next release then.
