file upload case and lower case file name
Thread begun 10/02/2012 2:02 am by Massimo | Last modified 10/08/2012 4:25 am by Massimo | 3930 views | 6 replies |
Massimo
my customer image have a case file extension:
when I upload file from file field in my dB are stored lower case:
but in server it remains case
How I can solve? Thanks
in the webassist/file_manipulation/helperphp.php file, change the following line:
$extension = isset($path_parts['extension']) ? $path_parts['extension'] : '';
$extension = isset($path_parts['extension']) ? strtolower($path_parts['extension']) : '';
Massimo
I was confused. I was wrong example
I have:
when I upload file from file field in my dB are stored same:
but in server only file extension is stored lower case so:
and I don't know if my customer use case or lower case extension
can you send a copy of your page please?
the server file name should use the same case as the file created on the server.
Massimo
this is the file
in the insert record behavior, you have bound the image column to the image form element.
In the bindings panel, there is a collection for WA Uploaded File (image), expand this collection and use the server file name binding instead.
Massimo
thanks. Now work
