JS problem
Thread begun 10/01/2012 10:49 am by info364504 | Last modified 10/03/2012 12:04 pm by info364504 | 2093 views | 4 replies |
info364504
JS problem
Hi, I have reinstalled DataAssist and now I get this message on DW start up:
"At line 21 of file "C:\Users....\DreamweaverCS5\en_US\Configuration\Sh ared\WebAssist\Preferences\RSSUpdate.js": WebAssist_getExtensionDataFromMXI is not defined."
I have deleted the .dat file but still same error....please help
Go to WebAssist -> Preferences in the Memento section Set the Show in dreamweaver option to Never.
In the RSS Section, check the option to disable all RSS Feeds and Check For Updates only when Memento opens.
Then go to Window -> Work Space layout -> Reset '<your layout name>'
info364504
I also get this message on DW start up:
unable to open script c:\program files\adobe\adobe dreamweaver cs4\configuration\shared\webassist\library\WA_Configuration.js
and this other message pops up a few times when DW starts:
unable to open script file c:\program files\adobe\adobe dreamweaver cs4\configuration\shared\webassist\DocumentEncoding.js
It sounds like you may have conflicting extensions installed.
Please provide a listing of extensions that are installed including version numbers.
info364504
Jason, thanks a lot for your time.
Luckily I had a backup copy of the configuration folder (don't know why because I never did it) and this fixed everything.
Cheers
