JS Error: WA_getExtensionDIR is not defined
Is there any way to figure out what I did when installing WA extensions to cause this error.
JS Error: WA_getExtensionDIR is not defined (see image)
Go to WebAssist -> Preferences in the Memento section Set the Show in dreamweaver option to Never.
In the RSS Section, check the option to disable all RSS Feeds and Check For Updates only when Memento opens.
Then go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
The problem seems to be fixed. Thanks.
