Add UE within a Joomla article using Jumi
Thread begun 9/27/2012 9:59 am by tmcbinc99963 | Last modified 9/27/2012 2:42 pm by tmcbinc99963 | 4151 views | 4 replies |
tmcbinc99963
As you probably know, Joomla editors can strip out php code when trying to use source code within an article. As a workaround, there's a third party Jumi component that prevents the code from being omitted, but requires putting a link within the article. This points to a separate html file that includes the source code. This is what I'm trying in order to get UE to work in Joomla - if there's an easier way, please advise. Otherwise...
Following is the syntax error I receive on page load:
Parse error: syntax error, unexpected T_VARIABLE in /homepages/20/d357158472/htdocs/test/Joomla_1/Contactus_Jumi.html on line 48
Attached is the Jumi file
You can view the error on submit at: index.php?option=com_content&view=article&id=120&Itemid=70
Additional info: I also tried saving as php file, but with same error result.
line 48 is missing a ">" comparison.
change line 48:
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts $EmailsRemaining)?0:($IntoBurst*$RealWait));
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
the change is subtle, but in the middle of the expression, this portion of code:
...($AfterBursts $EmailsRemaining)?...
should be:
...($AfterBursts>$EmailsRemaining)?...
tmcbinc99963
Thanks; the page now loads.
Now I get the following error on submit:
Fatal error: session_start() [<a href='plugins/function.session-start'>function.session-start</a>]: Failed to initialize storage module: user (path: /tmp) in /homepages/20/d357158472/htdocs/test/Joomla_1/Contactus_Jumi.html on line 55
Link to form: index.php?option=com_content&view=article&id=120&Itemid=70
Jumi file attached; updated per previous post.
this is an issue with the session management settings on your server.
you will need to contact the host to have this corrected.
tmcbinc99963
Will check it out, thanks.
