Subsequent Results Pages Showing Code
Thread begun 9/26/2012 1:00 pm by reiter303441179 | Last modified 10/09/2012 12:17 pm by Jason Byrnes | 5761 views | 16 replies |
reiter303441179
On subsequent results pages there is code intermingled in with the content which is not present on the initial results page. I figure there is something causing this but cannot figure out what. I've attached a screen shot. Thanks for your help
Cameron
the screen shot is not readable. can you also send a copy of the page so i can seer the code.
reiter303441179
Jason, here's a pdf of the page. I didn't know any other way to do it so if you need it another way let me know with a little instruction. I also did a different screen shot the pertains to the issue.
the following code on your page:
<a href="products_detail.php?ProductID=<?php echo($row_WADAproducts['ProductID']); ?>" ><?php echo(isset($_GET["pageNum_WADAproducts"])?"&pageNum_WADAproducts=".intval($_GET["pageNum_WADAproducts"]):""); ?>
should be:
<a href="products_detail.php?ProductID=<?php echo($row_WADAproducts['ProductID']); ?><?php echo(isset($_GET["pageNum_WADAproducts"])?"&pageNum_WADAproducts=".intval($_GET["pageNum_WADAproducts"]):""); ?>" >
it occurs in a few spots
reiter303441179
Thanks Jason. I never would have found that without your help.
Another question; How do I filter a filter? On the attached page I have a filter to filter the products by manufacturer. I'm trying to filter the manufacturers so only manufacturers populate who have products in the category being viewed. I have tried a "show if recordset not empty" but that won't work. Also, I have not been able to properly input an option for "show all" so that you can click on it to repopulate the page with all the products in the category after you've already filtered the results and want to go back.
how are manufacturers linked to products in your database?
using different types of joins in your query can achieve the results you are after to join the manufacturers and products table together.
Using a inner join will only return a result if there is a march in both tables. See this page for more details on join queriers:
Join_(SQL)
for details on clearing the search filter, see the following thread:
showpost.php?p=99028&postcount=2
reiter303441179
In the products table they are a number in a column which is converted to a name in another table named productmanufacturers. I don't know if that was what you were looking for.
I'll check out those other threads.
*Edit. So how would the innerjoin look like in the recordset?
Cameron
I cant really give an example of how your SQL would look, as i dont know how your database is structured.
The page i linked to has a number of examples for creating joined queries.
reiter303441179
Jason I got it to work with an inner join but it lists the manufacturers as many times as there are products for the manufacturer. So, if the manufacturer has 10 products in that particular category, the manufacturer is listed 10 times in the filter. Is there a way so that the manufacturer is listed only once? I figure it has something to do with my inner join.
Here's the inner join:
SELECT *
FROM productmanufacturers
INNER JOIN products ON productmanufacturers.ManufacturerID = products.ProductManufacturerID
WHERE ProductCategoryID = Category (I used this as it is the url parameter for the page)
ORDER BY ManufacturerName ASC
add a group by condition after the order by:
GROUP BY ManufacturerName
