Upload behavior won't work
Thread began 9/26/2012 8:55 am by lr_leal239405 | Last modified 9/26/2012 1:18 pm by Jason Byrnes | 1750 views | 5 replies |
lr_leal239405
My File Upload behavior doesn't work. I tried different things but I can't get it to work. The file seems to upload but when I go to the folder, it's empty. It's pointing to the right folder and the hosting co. says the folder is set up properly and it can receive any file up to 200mb. Here's the script that is is generated when I add behaviors: (I have 3 fields for uploading simultaneously and I tried each individually without success).
@session_start();
<?php require_once("webassist/file_manipulation/helperphp.php"); ?>
<?php // WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "Uploaded_Files/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End?>
// WA_UploadResult3 Params Start
$WA_UploadResult3_Params = array();
// WA_UploadResult3_1 Start
$WA_UploadResult3_Params["WA_UploadResult3_1"] = array(
// WA_UploadResult3_1 End
// WA_UploadResult3 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Submit"])){
WA_DFP_UploadFiles("WA_UploadResult1", "Upload1", "0", "", "false", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult2", "Upload2", "0", "", "false", $WA_UploadResult2_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult3");
WA_DFP_UploadFiles("WA_UploadResult3", "Upload3", "0", "", "false", $WA_UploadResult3_Params);
please send the full page
lr_leal239405
attached is the file. Thank you.
File_Upload.zip
looks correct.
to troubleshoot, add the following code at line 1:
error_reporting
(E_ALL);
ini_set('disaplay_errors','on');
then open the bindings panel, and expand the WA Uploaded files binding group and add the debug info binding to your page
and add this code just before the </body> tag:
echo("POST:<pre>");
var_dump($_POST);
echo(
"</pre>");
echo(
"FILES:<pre>");
var_dump($_FILES);
echo(
"</pre>");
post back the results after testing the upload. This will give us details about the upload to tell what may be going wrong.
lr_leal239405
There is no WA Uploaded files binding group. I expanded 'Upload files global status' and added the Debug Info instead. I also added Debug Info from 'Upload Files' (Upload1) which is my first field. I only tried uploading from this field. Here's what I got:
Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
Status object: WA_UploadResult2
statusCode : 0
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult2_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
Status object: WA_UploadResult3
statusCode : 0
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult3_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
statusCode : 0
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
POST:
array(1) {
["Submit"]=>
string(6) "Submit"
FILES:
array(3) {
["Upload1"]=>
array(5) {
["name"]=>
string(37) "bendailynewsmainartFINAL_ORIGINAL.jpg"
["type"]=>
string(0) ""
["tmp_name"]=>
string(0) ""
["error"]=>
int(1)
["size"]=>
int(0)
["Upload2"]=>
array(5) {
["name"]=>
string(0) ""
["type"]=>
string(0) ""
["tmp_name"]=>
string(0) ""
["error"]=>
int(4)
["size"]=>
int(0)
["Upload3"]=>
array(5) {
["name"]=>
string(0) ""
["type"]=>
string(0) ""
["tmp_name"]=>
string(0) ""
["error"]=>
int(4)
["size"]=>
int(0)
the key is in the results for the files array:
FILES:
array(3) {
["Upload1"]=>
array(5) {
["name"]=>
["type"]=>
string(0) ""
["tmp_name"]=>
string(0) ""
["error"]=>
int(1)
["size"]=>
int(0)
["Upload2"]=>
array(5) {
["name"]=>
string(0) ""
["type"]=>
string(0) ""
["tmp_name"]=>
string(0) ""
["error"]=>
int(4)
["size"]=>
int(0)
["Upload3"]=>
array(5) {
["name"]=>
string(0) ""
["type"]=>
string(0) ""
["tmp_name"]=>
string(0) ""
["error"]=>
int(4)
["size"]=>
int(0)
the results for the first one:
["Upload1"]=>
array(5) {
["name"]=>
["type"]=>
string(0) ""
["tmp_name"]=>
string(0) ""
["error"]=>
int(1)
["size"]=>
int(0)
show that it is returning an error code of 1:
["error"]=>
int(1)
error code 1 means that the file size exceeds the max_upload_file size set in php.ini:
features.file-upload.errors.php
the other 2 are failing because the first one is causing an error.
