Errors
Thread begun 9/26/2012 8:20 am by jo271221 | Last modified 9/26/2012 10:35 am by Jason Byrnes | 893 views | 1 replies |
jo271221
Errors
I am getting the attached errors. Also I have a group of fields that I want to be able to search - they are the pedigree fields, ie Sire, sires sire, dam, dam's sire... Is there a way to create the search so that it will search all of those fields? I assume their is with some custom coding, therefore when I complete the wizard is there anything special I should do to prepare for this?
here is an updated copy of the /Configuration/Shared/WebAssist/DataAssist/PageGeneration.js file that should correct the issue
for help locating the users configuration folder, see the Common installation issues page:
common_installation_issues.php
if you continue getting the same error, please provide some more details about When and where the error occurs and the settings being used for your application
