No Info Bubble on first map. Is it possible?
Thread begun 8/06/2009 9:00 am by Cactus Gary | Last modified 9/08/2009 8:15 pm by terry164844 | 8021 views | 11 replies |
Cactus Gary
I'm pulling data from a recordset and the map has many pins. Can just the pins be displayed when the map page is opened and no info bubble shown? Then the visitor can click the pin they want and see the info bubble?
Thanks, Gary
In the map include file find any line that starts:
marker.openInfoWindowHtml
and comment it out:
//marker.openInfoWindowHtml
To find the map include file, look at the code on your page before the </head> tag, for PHP, there will be a line similar to:
<?php include("google_javascript/wagmp_map_1.php"); ?>
The google_javascript/wagmp_map_1.php is the page to edit.
drostenator386534
removing marker window
I could not find this exact text "marker.openInfoWindowHtml"
in the "wagmp_map_1.php" file.
Could you provide more description about the location of the "comment out" in that file please?
thanks.
There will be multiple instances of the line that needs to be commented and the exact text may differ each time.
on example of the full line would be:
marker.openInfoWindowHtml(address_0.infowindowtext);
the:
address_0
portion may be differant however.
drostenator386534
Hi, I'm not seeing that either.
What I do see are multiple versions of this:
marker_0_<?php echo $SearchResults_id; ?>.openInfoWindowHtml(address_0_<?php echo $SearchResults_id; ?>.infowindowtext);
But commenting that off in all occurrences broke the page, and everything in the <?php ?> areas don't get commented. I tried deleting the lines too.
Can you please provide an even more detailed description of what to do, or paste the complete code of one that has the bubbles removed?
Thank you.
can you send a copy of your wagmp_map_1.php iun a zip file so I can look in to the issue.
colin282897
I have posted an additional thread on the same sort of subject, my problem is i also cant find the marker.openInfoWindowHtml in the .js file.
terry164844
Removing the info text bubble
I'm wondering if this was ever resolved. I would like the map to display but without the first location having the infotextwindow bubble.
Terry
Many people have been successful commenting out the lines of code to prevent the info window from opening. If you have a url I can try to point out the specific lines.
terry164844
Url For Map
fabulez-clubs.php
Also, I have to other questions:
1.) is there a way to know where someones clicks on the map so I can zoom in and also diplay from the recordset the records for that area? For example, someone clicks on Texas, then records only show Texas
2.) Is there a way to show a number or letter in the push pin that corresponds with the records shown on the left of the map?
Thanks for your help,
Terry
