Form php isn't securing
Thread begun 9/24/2012 12:40 pm by templemedia365477 | Last modified 9/25/2012 11:05 am by Jason Byrnes | 7738 views | 13 replies |
templemedia365477
seminole_order_form.php
This should be a secured page. When trying to get in through the back door, I'm getting the error:
"The page isn't redirecting properly
Firefox has detected that the server is redirecting the request for this address in a way that will never complete."
I think I've gotten this error before and it had to do with double code, but I can't see it in here. There is a file formaction.php which enables the order form - I did not secure it - a bit afraid to for fear of breaking the whole structure.
The rest of the site is working fine, including pages I've added and secured since the set up.
Looks like you set the Access Denied redirect to go back to the same page.
When adding the access restriction behavior, you have to specify an unsecured page for the if access Denied condition.
templemedia365477
that didn't work
I'm now working with the page seminole_order_form1.php and /login.php as the redirect.
Now, this page isn't secured at all... can pull it up without being logged in, no error. The rest of the pages I secured today are redirecting fine...
i'm not able to access that page, it seams to be secured to me.
templemedia365477
what is it doing for you? I can get in it on both computers and in IE and FF without login???
it redirected me last time tried accessing it, this time it let me in, what access rule are you using to secure it?
you should be using the Logged into <your user table>" rule, where <your user table> is the name of your users table.
templemedia365477
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
if (!WA_Auth_RulePasses("Logged in to users")){
WA_Auth_RestrictAccess("../login.php");
This is the code that is the top of the page, before the head code. Logged in to users is the only option - where to set the table??? And why are other pages working okay?
send a copy of a page that is working ok and a copy of the page that is not working so i can see the code for comparison
templemedia365477
working/not working
tried uploading from url and the file itself - invalid file format. Can I give you my ftp info and can you get in through there?
templemedia365477
both not uploading
both files will not upload to you - seminolefeed.com/Dealer_Site/logos.php (working) and seminolefeed.com/Dealer_Site/seminole_order_form.php (not-working).
