Encryption inconsistancy
I use "DataAssist Pages" to generate an insert page with a hash encrypted field.
If I edit the insert page it created, its Bindings, Value, lightning-bolt...the field with encryption applied is not recognized/populated; although I can point it to the correct value and change the encryption type...however it formats the value slightly different.
Also, if I create an insert page using "Insert Single Record"...and apply encryption to a field and then close...I notice that the wa_hashencryption.php file is not added to the file as was by the "DataAssist Pages".
Is there an inconsistency or broken functionality here?
I have not tested this live...I am a new user ripping though your tools and figuring out how they all work together.
Thanks,
Brent
