Template
Thread begun 9/21/2012 1:00 pm by Php | Last modified 11/01/2012 8:01 am by Jason Byrnes | 5430 views | 8 replies |
Php
Template
Hi, If I start dreamweaver and go to build new site using Site Sculptor and I use one of the predefined templates with added cms can I change the whole layout in dreamweaver? I am trying to do this through dreamweaver and it's not letting me only thing shows is the cms?
After you have created the site using Site Sculptor, you can edit the template file to change the site design.
Php
Site
Thanks for reply Jason and If I was to create a login data assist how will I insert into the site I have created by site sculpture?
apply the template to the pages created by the data assist wizard.
Php
Site
Ok thanks for speedy answer and finally last question, if I want my login to be in top right hand corner, how would go about doing that??
I can't see CSS files so dunno how I would do it?
Kind regards
Naz
add an editable region to your template where you would like the login to go. When you apply the template to the login page, it will ask you what editable region to put the login form in.
Php
Site
Thanks Jason
Php
Every page unique
Hi, I build a site using site sculptur I was thinking If I wanted some pages to be unique and different would I need to make different dwt files?
Kind regards
Yes, if you wanted different design for some pages, you would need another template to control those pages
