Vertical menu level 2 is wrong.
Thread begun 9/21/2012 3:41 am by Jonas | Last modified 9/25/2012 12:03 pm by Jason Byrnes | 2527 views | 5 replies |
Jonas
It seems to be a bug in the CSS Menu Writer. I have created a menu that will act as drop-down menu for mobiles. I've started from category: "Simple", type: "Vertical". Then I have created a new level 1, with only the word Menu. Then I moved all the headlines in level 1 to level 2.
By default, the width of each level is set to 150px. If you wish to change the width to 100px for example - will not level 2 display correctly. There is no way to change where level 2 is shown sideways in Menu writer. When I look in the CSS file, the rule: "ul # cssmw0 ul.level-2", it says: "left: 165px". This one must be able to influence even inside the Menu Writer.
What version of CSS Menu Writer are you using?
I am not able to reproduce this problem using Design Extender 1.1.1
Jonas
True wrong version
Version 1.08 was the version I was using. Now it works indeed better when I upgraded to the latest version. However, there will be other problems now. I guess this is because I want to create a special menu. Therefore, I would accept to manually change the ccs file. Here is my problem. The problem happens when I should change the order of content in level 2. If I move up or down one line, it disappears completely or end up in another.
in your screen shot, you have the bubble for step 2 on top of the Left arrow button? that button is used to move a submenu item to the next main menu.
the left and right arrow buttons change which menu level the item is a child of.
The Up and Down arrow buttons move the item in the current menu level.
Jonas
It disappears into thin air.
Step 2 is exactly as I write "Press down" and nothing else.
I want to move down Activities, under Recreation. But when I do this it will be as I wrote earlier. It disappears into thin air.
I am not able to reproduce this.
