Went where no one should have gone before
Thread begun 9/20/2012 2:59 pm by phill401410 | Last modified 9/21/2012 10:19 am by Jason Byrnes | 1219 views | 1 replies |
phill401410
I accomplished the Double Opt In Registration System tut successfully making a Registration page that entered data into my remote data base and sent me an email saying I could log in. Did not try all the functions and test all the pages but instead went right back into trying to customize the Registration page. I deleted the Security Answer and broke something. So I reloaded the Registration Page code that worked (I always make a copy of code that works) but , alas, something broke.
So I added trouble shooting code as you have instructed in the past and the Reg Page threw this error:
array(9) {
["WAENCRYPTEDRETURNUSED"]=>
&bool(false)
["WAENCRYPTEDRETURNSUCCESS"]=>
&bool(false)
["rpw"]=>
&string(8) "Bm^:j,2@"
["SubmitCount"]=>
&int(1348176651)
["random_question"]=>
&string(32) "Which number is lowest 99 or 20?"
["random_answer"]=>
&int(20)
["Last_CAPTCHA"]=>
&int(1348176634)
["captcha_Security_Code_1"]=>
&string(5) "T6dbE"
["WAVT_registration_Errors"]=>
&string(616) "WAVT_Registration_group_Email=jsafdhajfh@iju.cc&WAVT_Registration_group_Password=heather17&WAVT_Registration_group_Confirm=heather17&WAVT_Registration_group_First_Name=m&WAVT_Registration_group_Last_Name=m&WAVT_Registration_group_Address=m&WAVT_Registration_group_Address_2=m&WAVT_Registration_group_City=m&WAVT_Registration_group_State=m&WAVT_Registration_group_10_Zip=m&WAVT_Registration_group_11_Country=United States&WAVT_Registration_group_1_Phone=m&WAVT_Registration_group_1_Fax=m&WAVT_Security_Code=T6dbE&WAVT_Security_Answer=72&WAVT_Hidden_Field=&WAVT_Registration_submit=Register&WAVT_registration_Errors=14"
Thanking you in advance.
Attached is the the Reg Page php file and the code that works.
it's the captcha that is failing validation.
this code generates the captcha image:
<img id="capt1"  src="webassist/captcha/wavt_captchasecurityimages.php?width=150&height=40&field=Security_Code_1&bgcolor=FFFFFF&transparent=0&bgimage=&gridfreq=20&gridcolor=000000&gridorder=behind&noisefreq=20&noisecolor=000000&noiseorder=behind&characters=5&charheight=&font=fonts/MOM_T___.TTF&textcolor=336666" alt="security code" width="150" height="40" /><img  src="webassist/captcha/images/refresh.png" height="18" onclick="document.getElementById('capt1').src+='&ref=1'" />
this is passing a number of variables to the webassist/captcha/wavt_captchasecurityimages.php page as URL variables.
one of those variables is named field. the field variable is used to set the captcha session name, in your code, the filed variable is set as:
the captcha session name will be set as "captcha_<Field URL variable Value>", so in this case, the captcha session name is set as "captcha_Security_Code_1"
The problem is that in the Server Validation behavior, you have the Like Entry validation to use the session named "captcha_Security_Code" instead.
Edit the server validation server behavior, and change the like entry validation to use the captcha_Security_Code_1 session as the comparison value
