Random & inconsistent results page
Thread begun 9/18/2012 2:10 pm by Paul | Last modified 9/22/2012 8:35 am by Paul | 2792 views | 5 replies |
PaulBeta Tester
I've used the DA search wizard to build my search and results page.
For reasons unknown, my results page is responding inconsistently, occasional throwing a server shown below;
It works much of the time, however the query takes anything between 1 sec to over 2 minutes to resolve and return a response
html:
Server error!
The server encountered an internal error and was unable to complete your request.
Error message:
Premature end of script headers: GalleryList.php
I've attached the page as im not sure where to start looking - simply because it works as expected sometimes!
The search page is here;
http://www.crazyplumhomes.co.uk/d/property/index.php
I'm using a query in my results page that joins 12 tables - is that excessive? I've no idea.
Any help appreciated.
I forgot to add, theres only a few test records in my DB and the results query is not complex by any means. So im not exactly pushing full throttle on server /mysql resource.
Thanks.
What happens if you strip out all java scripting?
when i test your page, my javascript error console shows a number of problems:
  yanonekaffeesatz-light-webfont.woff:-1Resource interpreted as Font but transferred with MIME type text/plain.
ubuntu-light-webfont.woff:-1Resource interpreted as Font but transferred with MIME type text/plain.
top-links.pngGET top-links.png 404 (Not Found)
top-links1.pngGET top-links1.png 404 (Not Found)
script.js:307[cycle] terminating; zero elements found by selector
viewing source of your page, it looks like you are using a number of HTML 5 techniques, but you use the XHTML doctype:
PaulBeta Tester
Many thanks to Ray for his time and effort explaining and showing where this was going wrong.
It was an inefficient and poorly structured My SQL query that was causing the issue.
Problem resolved.
PaulBeta Tester
Close to a full solution...
Ray, i've attempted to add another couple of JOINS to the following sql you showed me recently;
mysql_select_db
($database_HouseyConnect$HouseyConnect);
$query_WADApropsubtbl "SELECT hopicfolder, hopicimagename, propRooms, propType, propmaintbl.propVal, propSDesc FROM propmaintbl
LEFT OUTER JOIN homepics ON PropPrimePic = hopicsidx
LEFT OUTER JOIN propRooms ON propBeds = propRoomCnt
LEFT OUTER JOIN propstyle ON propType=PropStyleCnt
LEFT OUTER JOIN propval ON propmaintbl.propVal = propValCnt
WHERE propRID = "
$row_WADApropmaintbl['propRID'];
$WADApropsubtbl mysql_query($query_WADApropsubtbl$HouseyConnect) or die(mysql_error());
$row_WADApropsubtbl mysql_fetch_assoc($WADApropsubtbl);
The first two are good, but 3 & 4 return the error; Unknown column 'propValCnt' in 'where clause' and Unknown column 'propSaleCnt' in 'where clause' instead of the results page, when i apply the respective search criteria.
I've followed the same principles as 1&2 - well at least i thought i had;
Join TABLE1 ON TABLE2_TARGET_FIELD_NAME = TABLE1_INDX_FIELD_MATCHING_TABLE2_TARGET_FIELD_NAME
Not sure why failing?
i would need to see the structure for the tables you are using in this query to be able to troubleshoot.
when creating join queries, it is a good practice to include the table name in the ON clause:
INNER JOIN table2 ON table1.KeyColumn = table2.RelationColumn
You may have better luck creating your query using a visual query builder like SQLYog or Navicat
PaulBeta Tester
Thanks Jason,
I've resolved.
I needed to enter the search form fields into the Server Behaviour Config page by hand in the DA Search Wizard.
I get that these are enterable when thwe wizard is run first time, however i think it would be useful to have these selectable post-edit too!
I assume it maybe difficult, since they exist on a different page tho!
