Trouble with Checkout Wizard
Thread begun 9/18/2012 12:12 pm by Joe Lowery | Last modified 9/18/2012 3:36 pm by Joe Lowery | 1743 views | 2 replies |
Joe Lowery
I wanted to have a cart display on my checkout page, so I duped the cart.php and renamed it checkout.php. Then I ran the Checkout Wizard on that page. After going through all the steps, I clicked Finish and the dialog closed - but that was it, nothing was added to the page.
Did I misunderstand the process? I tried it with a blank page and got the message that I needed a checkout button on the page. Am I doing anything wrong?
Thanks - Joe
instead of renaming the cart page.
start with the existing cart page, then run the checkout wizard.
after the checkout wizard is completed, add the cart display manager to the checkout page that isn created by the wizard.
you'll want to make sure and use a read only display
Joe Lowery
Great - that worked, it just took a long time for the pages to be created. Too bad you can't put up a "Working..." graphic or something similar.
Thanks again.
