Data bridge: Col has no properties
Thread begun 9/17/2012 12:14 pm by eladgraphics386618 | Last modified 9/26/2012 12:39 pm by eladgraphics386618 | 4925 views | 9 replies |
eladgraphics386618
Hello
I have upgrade to super suite
1) Data bridge is giving me this message (3 times after I uninstall and re-install)
While executing in wa_sitetool_progressV2.htm, the following javascripts error occurred:
At line 751 of
“c:\.................configuration/floters/wa_sitetools_progressV2.js”
2) unable to find file Wa-memento.htm in the configuration/floaters directory. the floaters will not be shown.
3.) Contact Form Builder will not let me add another line or another set in the edit mode
thanks so much.
eladgraphics
for the errors:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
for the problem with form builder, if you upgraded to the latest version of supper suite, you should only have 3 extensions now:
eCart
Design Extender
Data Bridge
Make sure that eCart was not the last one that you installed.
eladgraphics386618
Hello Jason
Thanks for fast response. I will try your suggested help and hope it will correct everything.
I have cleared everything and have only 3 extensions. I am talking about contact form builder inside data bridge.
Hope everything will work out fine. Will keep you posted
Again thanks so much.
eladgraphics
eladgraphics386618
Hello Jason
I have applied the fix you suggested and it worked for the data assist but did not correct the problem with the contact for.
In contact form (simple contact) when I was trying to add a phone line , it does not allow me to do that. When I click on the + sign nothing happen but when I tried the delete (-) that one worked and took the line or set away.
What should I do.
thanks again
eladgraphics
eladgraphics386618
Hello Jason
Data Assist
The fix worked only for the admin side, on the public side I had the same problem.
I reapplied the same fix and the same problem occurred for 2 more times and I uninstalled the extension and reinstalled it.
When I tried again this is the error message I got.
"while executing onUnload in WADA_Main.htm the following javaScript error(s) occured
In file "WADA_Main". WA is not defined.
Contact Form
I have tried again the contact form, the + in the edit page work sometime, sometime not.
I was able to add one line and when I made the contact form.
I could not get the form direct to the thank you page when you filled it up.
I am attaching the zip file. the site is www.maryafricanhairbraids.com
eladgraphics
thanks
The full name text field in your form uses a space in the name.
Spaces are not valid for naming form elements.
you should avoid using spaces when naming form elements.
eladgraphics386618
Hello
1. Thanks a lot for the support.
2. Data assist (public page )
On my result page, I have "add to card" "delete " buttons.
I am trying to have a blog page and I don not need those button on the result page.
How do I take them out or do you have any suggestion for me as to how to generate the result page without to button. ( need only the picture, title, date and description)
thanks so much again for your support.
eladgraphics
When running the Create pages wizard, go to the manage pages tab to edit the results and details pages to uncheck the option to include the delete button. This will create pages that don't have the delete button in place.
to remove the delete button or add to cart button after the pages are created, select them in design view, and press the delete key on your keyboard.
eladgraphics386618
Hello jason
thanks so much for your reply.
I will try it.
Again very much appreciated
eladgraphics
