Record Insert Ceases to Work
Thread begun 9/14/2012 10:28 am by Mike Perry | Last modified 9/14/2012 11:10 am by Mike Perry | 2351 views | 4 replies |
Mike Perry
I have a Client Management page that is used to add products to a Product Table. It was up and running fine; now it fails to insert one of the two fields.
It works fine on my local server (Apache/2.2.22 (Win32) PHP/5.2.17/ MySQL 5.0.51a) However on the NS server (Apache/2.2.22 (Unix) / PHP 5.3.8 / MySQL 5.1.56) the brand is not inserted into the brand field.
This was developed with Datat Assist, not Data Bridge.
Insert Page attached -- thanks. . .
which one of the fields is failing?
This is important to know in order to know what to look for.
Mike Perry
:eek:
Sorry -- Brand Field. . .
in the insert record behavior, you have the BrandName column bound to the bName form element, you should be using the BrandName form element instead.
Mike Perry
Got it. . .
Wonder why it worked locally? Anyway, I recall you and I went round & round getting the Dynamic Dropdowns working on this page (my skull thickness!), so thanks again!!
