Data Dridge DataAssist Error Message
Thread begun 9/14/2012 6:01 am by johna1964 | Last modified 9/14/2012 7:45 am by Jason Byrnes | 919 views | 1 replies |
johna1964
Hi!
I ran the Data Assist Wizard part of Data Bridge. By the way, it is so nice!
When I attached the DW template to the pages, all went well with the exception of the update page:
( ! ) Notice: Undefined index: ProductID in C:\wamp\www\testsite\admin\products_update.php on line
817
Call Stack #TimeMemoryFunctionLocation 10.0028571048{main}( )..\products_update.php
0 " />
At the very bottom of the page, outside of the fieldset. This is the code from line 817 and 818:
<input type="hidden" name="WADAUpdateRecordID" id="WADAUpdateRecordID" value="<?php echo((isset($_GET["invalid"])?ValidatedField("productsupdate","WADAUpdateRecordID"):$_GET["ProductID"])); ?>" />
</form></div><div id="Update_Cool_Default_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
I have attached a copy of the page.
I have know idea how to fix this.
Thank you!
johna1964 :confused:
are you visiting the page directly without using an update link from the results page?
the error suggests that there is no ProductID querystring variable being passed in which would pretty much make for a useless update page since the ProductID querystring is used to populate the form.
make sure you are using an update link from the results page to get to the update page.
